SALUT LUC . POUR REPONDRE A TES ?S /
-POUR LES VITRES TEINTEES IL TE FAUT DE L EAU ET DU SAVON (DU LIQUIDE VAISSELLE ),ET UNE RACLETTE EN PLASTIQUE SOUPLE . TU METS L EAU ET LE SAVON DANS UNE BASSINE PUIS TU MOUILLES TA VITRE . TU POSES TON FILM TEINTE SUR TA VITRE . TU PRENDS TA RACLETTE , ET TU ENLEVES LE SAVON ET LES BULLES ENTRE TON FILM ET LA VITRE .PUIS AVEC UNE BONNE LAME TU COUPES LE SURPLUS DU FILM
-POUR LE FILTRE ,C EST UN POWER F1 BMC. IL TE FAUT UN FER PLAT DE L X l X H = 105 X 95 X 3 mm,+UN TUBE EN FER DE 80mm DE DIAMETRE DE L INTERIEUR DU TUBE .TU FAIS UN TROU DE 80 DE DIAMETRE DANS L AXE DU FER PLAT ,PUIS TU FAIS LES 4 TROUS DE DIAMETRE 4 OU 5 POUR METTRE TES BOULONS DE FIXATION. TU SOUDES LES 2 PARTIES ENSEMBLE.LE FILTRE SE FIXE AVEC UN COLLIER SUR TON TUBE EN FER QUI EST FOURNI AVEC LE FILTRE .LE RESULTAT DU FILTRE EST LE SIFFLEMENT DE L ASPIRATION DE L AIR QUI ME FAIT REVASSER Super14.gif
